14 years agoConfiguring ADC using FPGA
I am trying to configure an ADC using an FPGA. I can read the default values from the ADC register properly, but I'm unable to write to those registers. The fpga clock is 48 MHz and serial clock ...
14 years ago --- Quote Start --- Are you sending the right values for the W1/W0 fields? Cheers, Dave --- Quote End --- I think so. I want to write 1 byte of data, so W1/W0 is "00"
SIGNAL DATA_TO_ADC : STD_LOGIC_VECTOR(NUM-1 DOWNTO 0) := '0' & "00" & ADC_WRITE_REG & ADC_DATA;where ADC_DATA is declared as an 8-bit value.
