14 years agoConfiguring ADC using FPGA
I am trying to configure an ADC using an FPGA. I can read the default values from the ADC register properly, but I'm unable to write to those registers. The fpga clock is 48 MHz and serial clock ...
14 years ago --- Quote Start --- SPI CS is permanently tied low which is valid according to the datasheet. --- Quote End --- Ok. That fact was not mentioned in your post, so I wanted to check. --- Quote Start --- The only change between reading and writing is the number of bits sent to the ADC. The ADC is able to decode the address I send it, otherwise I would not read the correct values back. --- Quote End --- Are you sending the right values for the W1/W0 fields? Cheers, Dave
