Configuration via Protocol (CvP) fail after loading the periphery image
Can you try Kernel 5.1*.50 and above? I have check internally and it is updated in 5.1*.50 and later kernel version. Maybe you may try 5.15.100-lts.
- JonGoh1 year ago
Hi @JohnT_Intel ,
Yes the design of PCIe Gen3x8 is loaded into the FPGA. I am using Ubuntu 22.04, and used kernel version of 5.15.30-lts at first, and also tried 6.6.37-lts and encountered the problem mentioned above. I also attempted to compile 5.15.100-lts, but there seems to be an error in compiling, here is the error.
fs/ksmbd/smb2pdu.c: In function ‘smb2_write’:
fs/ksmbd/smb2pdu.c:6478:13: error: ‘is_rdma_channel’ undeclared (first use in this function)
6478 | if (is_rdma_channel == false) {
fs/ksmbd/smb2pdu.c:6478:13: note: each undeclared identifier is reported only once for each function it appears in
make[2]: *** [scripts/Makefile.build:289: fs/ksmbd/smb2pdu.o] Error 1
make[1]: *** [scripts/Makefile.build:552: fs/ksmbd] Error 2
make: *** [Makefile:1910: fs] Error 2Meanwhile, I'll try other versions from what you mentioned above,
Jon
