MRavi1's avatar
MRavi1
7 years ago
Compilation error in pipemult project.
Error (275021): Illegal wire or bus name " " of type signal
Error (12153): Can't elaborate top-level user hierarchy
Error: Quartus Prime Analysis & Synthesis was unsuccessful. 2 errors, 2 warnings
Can anyone please help me understand what exactly I should do to rectify it?
  • NSola3's avatar
    NSola3
    Can you share the source codes files for this or link for the same?
  • sstrell's avatar
    sstrell
    Just to explain a bit clearer, you have clock and wren connected as busses (thick lines) instead of individual wires (thin lines). Delete the busses and use the wire tool to make the connections. Also, the reset input into the register (CLRN) should be hooked up as well, either to an I/O pin or perhaps even just pulled high.
    #iwork4intel
    • MRavi1's avatar
      MRavi1
      Yes. I tried that too, I just had some problems with installation. Once I re-installed the software it worked fine. Thanks !
  • Vicky1's avatar
    Vicky1
    Check the connections of clock,wren(need to be wire) of ram instance & PRN, CLRN should connect inputs using pin tool.
    please let me know if you have any different concern.
    Vicky
