17 years agoCombining AS and PS configuration schemes
I'm designing a custom board with one Arriagx and 3 cyclone III. I would like to connect an EPCS with each Cyclone and configure the cyclone with the Arria. It means that I have to used the AS configuration(EPCS) and the multiple PS configuration(Arria) together. Can I combine easily the two configurations or should I differentiate the two configurations with jumpers? Has somebody already worked like that? thank you much, ben3 Replies
In my opinion, it can be save. I think, Altera wanted to issue a warning, that an undefined MSEL state during power up can cause inpredictable device behaviour. If you drive MSEL by an Arria, that is typically releasing the power-up reset at the same time as the slave Cyclone FPGAs, you should think about a means as strong pull-up/pull-down resistors or additional drivers to ensure stable MSEL conditions. In any case, you should try yourself, what must be done.
Hi FvM,
you're right , my plan was to change the MSEL by soft but also the DCLK and DATA0 pins. In the evaluation board from altera , the max command the MSEL pin in order to choose the configuration scheme. They have a AS configuration or a PS configuration. I would like to do the same. The difference with a evaluation board is that I don't have any MAX but an arria and I have 3 cyclone. But in your opinion it's not a save solution. - Altera_Forum
Your plan involves changing the MSEL pin strapping, that is sampled on FPGA power-on reset. Altera suggests not to use logic to drive these pins, so jumper or switches would be a save solution.
