17 years agoCombining AS and PS configuration schemes
Hi, I'm designing a custom board with one Arriagx and 3 cyclone III. I would like to connect an EPCS with each Cyclone and configure the cyclone with the Arria. It means that I have to used t...
17 years agoHi FvM,
you're right , my plan was to change the MSEL by soft but also the DCLK and DATA0 pins. In the evaluation board from altera , the max command the MSEL pin in order to choose the configuration scheme. They have a AS configuration or a PS configuration. I would like to do the same. The difference with a evaluation board is that I don't have any MAX but an arria and I have 3 cyclone. But in your opinion it's not a save solution.
