17 years agoCombining AS and PS configuration schemes
Hi, I'm designing a custom board with one Arriagx and 3 cyclone III. I would like to connect an EPCS with each Cyclone and configure the cyclone with the Arria. It means that I have to used t...
17 years agoIn my opinion, it can be save. I think, Altera wanted to issue a warning, that an undefined MSEL state during power up can cause inpredictable device behaviour. If you drive MSEL by an Arria, that is typically releasing the power-up reset at the same time as the slave Cyclone FPGAs, you should think about a means as strong pull-up/pull-down resistors or additional drivers to ensure stable MSEL conditions. In any case, you should try yourself, what must be done.
