16 years ago
code problem
Hi, I am wring a mermory code, but the waveform is not correct. There is no change of fin_add, only when add_en='1' then add_en_next change. I think probable it is coz the used(num) never become zero. but I don't know this happen. my code is as folllow:
architecture behv of mry is
signal num,match_num:integer;
signal used:std_logic_vector(3 downto 0);--!
type CAM is array(0 to 3) of std_logic_vector(15 downto 0);
signal data_array: CAM;
begin
process (init,add_en,num,used)
begin
fin_init<='0';
fin_add<='0';
add_en_next<='0';
if init='1' then --init
used<=(others=>'0');
fin_init<='1';
elsif add_en='1' then ---add
for num in 0 to 3 loop
add_en_next<='1';
if used(num)='0' then ---cell is empty
add_en_next<='0';
used(num)<='1';
data_array(num)(15 downto 8)<=H_Dn;
data_array(num)(7 downto 0)<=H_GD;
fin_add<='1';
exit;
end if;
end loop;
end if;
end process;
end behv;
    I was just describing the situation why the "fin_add" never changes. At the beginning there is the code
    --- Quote Start ---
    begin
    fin_init<='0';
    fin_add<='0';
    --- Quote End ---
    and logically there should be a change of the fin_add after something changed in the sensivity list.
    But since the process exectution enters the IF branch - fin_add<='1' and only last assignment in the process takes place. Therefore he will not notice '0' assignment on the waveform.
    Thats true
    If his fin_add always = '1' this means that his process always enters to the branch there fin_add assigned '1'.
    The problem can be in the testbench.
    Apart from the question, if the presented code as a whole has a reasonable operation (I said, why it can't in my opinion), the usage of fin_add and fin_init in the process is reasonable as such. But when the for loop iteration is translated to combinational code, these signals loose their original function. As uilka_b pointed out, they never change, respectively they are eliminated.
