14 years agoClock Skew doubt
Clock period = (register to register delay) - (clock skew) + Micro Tco + Micro Tsu Why are we subtracting "clock skew" Thanks, AAHello,
Clock period = (register to register delay) - (clock skew) + Micro Tco + Micro Tsu Why are we subtracting "clock skew" Thanks, AAHi again,
I looked at slide 15&16. Obviously it is about the way classic tool (slide 15) and TimeQuest(slide 16) deal with regard to clock skew issue. The demo assumes zero clock skew to begin with then injects skew of 2ns through PLL. Thus the PLL actually advances clock by 2 ns (but termed delay because actually PLL delays clk by 8 ns and clock edge wraps up as -2ns). In both slides setup slack is calculated as: slack=setup relatioship + clock skew - data delay. Now let us look at original setup slack equations: Clock Setup Slack = Data Required Time – Data Arrival Time this is obvious. then: Data Required Time = Latch Edge + Clock Network Delay to Destination Register –micro tSU – Setup Uncertainty Data Arrival Time = Launch Edge + Clock Network Delay to Source Register +micro tCO + Register-to-Register Delay if we now substitute: slack = (Latch edge - launch edge) + (clk delay to dest-clk delay to sou) + - micro tSU -micro tCO - data delay [ignore uncertainty) hence: slack = setup relationship + clock skew -(micro tSU+micro tCO) - data delay So here I want ask Altera!! what happened to -(micro tSU +micro tCO) term in above equations. Is it implied and computed internally when fmax is decided and hence set to zero? I don't believe so. It could be that the demo wants to be friendly while actual tool subtracts the above term. Notice that with classic timing or timequest case, the whole idea of using clock offset or clock latency is a tool specific issue. At the end of the day the register have to latch at the physically occuring edge. It is matter of getting the tool right. Thus in slide 15 setup relationship is 2 ns while in slide 16 it is 12 ns. clock skew is zero in slide 15 but 2 ns in slide 16. Though we are talking about same one circuit. It is all a matter relative to tool maker's mentality. Frankly, it is a mess to unlearn one tool and deal with a new tool. The designer's feel factor quality is never an issue in the market.Opps sorry! Yes, I had mistakenly written Tsu instead of "setup relationship".After reading your reply in post 12 I understood more about timing and I answered my questions.
To my question, are these the right answers? a. Yes, it is the right reason to cut it. Yes, the error just doesn't show up in the Analyzer, but the errors occurs in the hardware. b. The Quartus automatically takes care of it by inserting synchronizes and FIFO. c. Yes, it is the right thing to do. Yet to read post# 13 Thanks, AAa. yes
b. no, you the designer inserts synchroniser directly or by using dc fifo... c. yes and no. you should say unrelated clocks rather than Different clocks which may be related e.g. 20MHz and 40MHz may be related if say generated from one other clk and you can synchronise between them.always @(posedge clock_a) begin
reg_a <= temp; end always @(posedge clock_b) begin reg_b <= reg_a; end What happens when I synthesize this? [say clock_a = 22.4Mhz and clock_b = 45.4Mh, assume these frequencies are available]. Will I always get wrong data from reg b? c. I want to clarify, what should come to my mind when I hear the term "unrelated clock" and "related clock" ?. My understand was, "if two clocks are have different frequencies and if rising_edge_clock_a = n * [rising_edge_clock_b] for n= 1,2,3.. then clocks are related. d. Does the term "related" and "unrelated" has to do something with the clocks derived from the pll. Eg. all the clocks derived from pll are related [irrespective of the fact that their rising edge may not coincide] with each other. Thanks, AAHello kaz,
Thanks for breaking up the equations in post# 13. I am still understand the slide 16. I guess its easier for me since I am learning Time Quest and haven't used older version. Thanks, AAHi AA,
I am going to work tomorrow and may not be free to post. So I will add some info about io timing to complete the RTL chain: How does io timing come into the scene? The fpga input registers are at the mercy of the outputs from the external input device signals. Similarly, the input registers of the external output device are at mercy of fpga output signals. These two sets of nodes are no less important than fpga internal RTL chain. Here, designers are on their own to get it right by reporting correct figures to the tool. At the very start, you need to allocate responsibility of io timing closure; is it the fpga responsibility or the external devices or shared? Let us first assume that fpga is responsible for both ends. For fpga input register timing, the designer must know the input data relationship to its clock (tCO of external device as well as board delays). In essence they need to know data/clock relationship at input pins of fpga. If such information is not available then the timing tool is unable to report on the paths to these registers (and does not give warnings). For the external device input register timing, the designer needs to get information about their requirements and board delays. Many devices have tSU/tH requirements (figures apply to their pins rather than internal registers). Some modern devices do not have these requirements because they have opted for automating clock tracking features but then they still require minimum skew of the received data bus. If the fpga input registers timing is not the responsibility of fpga then the external input device needs to know fpga tSU/tH at pins and board delays. Similarly if the external output device takes over responsibility then it needs to know tCO of fpga and board delays or perhaps just the fpga data skew range. To my understanding, the above discussion is the basis of TimeQuest system-centric Versus fpga-centric methods. System centric implies fpga is responsible for the system. Fpga centric implies external device is responsible (not fpga). Thus fpga centric approach reports the tSU/tH of fpga input pins just like say a DAC chip does. And it reports on FPGA output pins tCO just like an ADC chip does. It does not take responsibility of system timing. Therefore, it is no surprise that these two methods give different results and they are not alternatives that you can simply choose whichever at will. edit: having said that, the fpga centric approach can be adapted to meet external device requirement i.e. knowing the external device information you may opt to calculate best tSU/tH or tCO to match instead of system centric approach.Hello Kaz,
Thank you, I am reading manuals and watching some videos. Your posts are clarifying my thought process to some extent. Thanks again, AA
