14 years agoClock problem
Hi All, I am trying to reduce the clock frequency from 25 MHZ to 12.5 MHZ using VHDL. I also intend to implement this in hardware, however I am having a lot of difficulty with my c...
14 years agoHi All,
I managed to get the following code working after I initially had some problems in declaring variables and generally not understanding the code. I have hardware on which there is a 25 MHZ crystal oscillator and I have reduced that frequency to 1 HZ. It worked on the simulator and on the hardware as I assigned the output to an LED. Cris kindly posted me some code and I thought it would be more beneficial for my progress I continued with mine. I have a couple of questions. 1) Is my code OK, 2) Is this the correct way to approach the problem, I have tackled it more as a software problem and VHDL is a hardware language. Would it be more proper for me to create divide by 2 counters in vhdl in order to reduce frequency. Thank you in advance for your help. My code -- Standard libary delarations library ieee; use ieee.std_logic_1164.all; -- define input and outputs for the entity entity led is port( clk_in: in std_logic; clk_out: buffer std_logic; clk: buffer std_logic); end led; -- internal function of enetity architecture behave of led is --internal variable signal count : integer :=1; begin process (clk_in,clk_out) begin -- Required in order to convert the sinewave to a square wave clk_out <= not clk_in; -- Check for rising edge of clock if(clk_out'event and clk_out='1') then --increment the count variable by 1 count <=count+1; -- when count is 2 if(count = 1250000) then clk <= not clk; count <= 1; --assign 1 to the variable which will be assigned to an output pin end if; end if; end process; end behave;
