16 years ago
clock gating issue
Hello All
I am using quartus for stratix3 device.
I have few clock gating module in desung and switch on the Auto_Gate_Conversion in quartus software to remove them.
I am using timequest and also generated sdc file.
The quartus does not convert the clock gate cell.
In the map report its written:
; Gated Clock Conversion Details ;
; Gated Clock ; Base Clock ; Converted to Clock Enable ; Reason not Converted ;
; phy_fe_unit_wrap_ctrl|phy_fe_unit_wrap_ctrl_i|dan_gclk:dan_gclk_i|gclk ; phy_fe_clk ; No ; Found register phy_fe_tx_cfr|phy_fe_tx_cfr_i|cfr_dout_real[15] fed by the gated clock tree has in-use clock enable ;
Can someone explain me this report?
How do i solve this problem?
Rami
