14 years agoClassic Timing Analyzer
In the timing analyzer report, it was mentioned that Fmax is restricted to 237.53 MHz, but by viewing the critical path :
The summation of the delays is not 4.21 so why the frequency is restricted to this value? Here are the delays : Info: Clock "CLK" Internal fmax is restricted to 237.53 MHz between source register "countfsm:u2|PS.seventeen" and destination register "countfsm:u2|Q_reg1[2]" Info: fmax restricted to clock pin edge rate 4.21 ns. Expand message to see actual delay path. Info: + Longest register to register delay is 1.184 ns Info: 1: + IC(0.000 ns) + CELL(0.000 ns) = 0.000 ns; Loc. = FF_X113_Y31_N9; Fanout = 4; REG Node = 'countfsm:u2|PS.seventeen' Info: 2: + IC(0.405 ns) + CELL(0.284 ns) = 0.689 ns; Loc. = LCCOMB_X113_Y31_N0; Fanout = 2; COMB Node = 'countfsm:u2|WideOr3~10' Info: 3: + IC(0.236 ns) + CELL(0.154 ns) = 1.079 ns; Loc. = LCCOMB_X113_Y31_N16; Fanout = 1; COMB Node = 'countfsm:u2|WideOr2' Info: 4: + IC(0.000 ns) + CELL(0.105 ns) = 1.184 ns; Loc. = FF_X113_Y31_N17; Fanout = 1; REG Node = 'countfsm:u2|Q_reg1[2]' Info: Total cell delay = 0.543 ns ( 45.86 % ) Info: Total interconnect delay = 0.641 ns ( 54.14 % ) Info: - Smallest clock skew is 0.000 ns Info: + Shortest clock path from clock "CLK" to destination register is 3.219 ns Info: 1: + IC(0.000 ns) + CELL(0.000 ns) = 0.000 ns; Loc. = PIN_J2; Fanout = 1; CLK Node = 'CLK' Info: 2: + IC(0.000 ns) + CELL(0.832 ns) = 0.832 ns; Loc. = IOIBUF_X0_Y36_N1; Fanout = 1; COMB Node = 'CLK~input' Info: 3: + IC(0.188 ns) + CELL(0.000 ns) = 1.020 ns; Loc. = CLKCTRL_G4; Fanout = 23; COMB Node = 'CLK~inputclkctrl' Info: 4: + IC(1.591 ns) + CELL(0.608 ns) = 3.219 ns; Loc. = FF_X113_Y31_N17; Fanout = 1; REG Node = 'countfsm:u2|Q_reg1[2]' Info: Total cell delay = 1.440 ns ( 44.73 % ) Info: Total interconnect delay = 1.779 ns ( 55.27 % ) Info: - Longest clock path from clock "CLK" to source register is 3.219 ns Info: 1: + IC(0.000 ns) + CELL(0.000 ns) = 0.000 ns; Loc. = PIN_J2; Fanout = 1; CLK Node = 'CLK' Info: 2: + IC(0.000 ns) + CELL(0.832 ns) = 0.832 ns; Loc. = IOIBUF_X0_Y36_N1; Fanout = 1; COMB Node = 'CLK~input' Info: 3: + IC(0.188 ns) + CELL(0.000 ns) = 1.020 ns; Loc. = CLKCTRL_G4; Fanout = 23; COMB Node = 'CLK~inputclkctrl' Info: 4: + IC(1.591 ns) + CELL(0.608 ns) = 3.219 ns; Loc. = FF_X113_Y31_N9; Fanout = 4; REG Node = 'countfsm:u2|PS.seventeen' Info: Total cell delay = 1.440 ns ( 44.73 % ) Info: Total interconnect delay = 1.779 ns ( 55.27 % ) Info: + Micro clock to output delay of source is 0.230 ns Info: + Micro setup delay of destination is -0.018 ns Thanks in advance.No RepliesBe the first to reply
