14 years agoCircular Buffer Implementation
Good morning. Am trying to implement a circular buffer to write to external SRAM. I am using two always constructs. The first determines that something should be written (there are multiple potent...
14 years agoI have some questions for you. Where is your external SRAM that you were talking about? sram_buffer in your code are going to be implemented as registers or internal ram depending on how you access it. Do you want a 256 byte memory? You just have a 20 byte memory (20x8 bits) in sram_buffer. Also doing three writes and additions within the same clock cycle (second always) is a bit much for a regular ram. One of the hardest things to do coming from a software background going to HDL/FPGA is to be able to envision what hardware your code turns into.
