17 years agochange the langage of the Nios
Hi, I work on an example project. The Nios was creating in verilog (so the toplevel is in verilog). Do you know if there is an option for changing verilog in vhdl ? Or do you know a go...
16 years ago --- Quote Start --- I am using quartus v9.1 and I found that changing "VERILOG" to "VHDL" in the .sopc file was not sufficient. I had to find all of the references to "VERILOG" or "verilog" and change them to "VHDL" or "vhdl" in the following files: nios2.ptf nios2.ptf.8.0 nios2.ptf.bak nios2.ptf.pre_generation_ptf nios2.sopc nios2.sopcinfo sopcb_tb2_nios2.xml Only then did sopc builder actually spit out a vhdl version of the system rather than a verilog one. --- Quote End --- All of the files you listed except the .sopc file are generated by SOPC builder. You can just change the reference in the .sopc file, delete the rest of them, then regenerate the system.
