17 years agochange the langage of the Nios
Hi, I work on an example project. The Nios was creating in verilog (so the toplevel is in verilog). Do you know if there is an option for changing verilog in vhdl ? Or do you know a go...
17 years agoWith SOPC Builder closed, open the .sopc file for your project in a text editor and change the line:
<parameter valueString="VERILOG" name="hdlLanguage"/> to: <parameter valueString="VHDL" name="hdlLanguage"/> next time you open the project in SOPC Builder it should generate the system in VHDL I've not found a way of doing this through the GUI but I'm still using 7.2SP3 - later versions may have implemented this properly.
