Center aligned output clock for ALTLVDS_TX in external PLL mode (Arria V)
I am using the ALTLVDS_TX core for transmitting differential data that was previously received by the ALTLVDS_RX core. The target device is an Arria V FPGA. The input/output data rate is 800 Mbps (400 MHz DDR clock).
To avoid having an asynchronous clock domain crossing between RX and TX I am using the ALTLVDS cores in external PLL mode as described in UG-MF9504. The data received by the ALTLVDS_RX core is center-aligned (as opposed to edge-aligned which is the case discussed in UG-MF9504).
As suggested by the user guide, I first generated the ALTLVDS_RX and ALTLVDS_TX cores using the internal PLL mode to determine the PLL parameters (frequency, phase shift, duty cycle) for the required PLL clocks. I then switched to external PLL mode and instantiated a PLL with the corresponding parameters.
The problem is that in external PLL mode there is no way to specify a phase shift for the ALTLVDS_TX output clock (tx_outclock) which is required to that the output data is center aligned with the output clock.
I added an additional output clock to the PLL with the desired frequency (400 MHz) and phase shift with respect to the ALTLVDS_TX output data. The resulting wave-form is correct according to the simulation. However, when measuring on the board the TX clock and data are not center aligned.
Is there a way to achieve center-aligned output clock when using the ALTLVDS_TX core in external PLL mode?
- SWrig4
Hi
when generating a ALTLVDS_TX using the MegaWizard, it is not possible to specify a phase shift is the "Use external PLL" option is selected.
For the PLL I am using the phase shifts reported in the resource report when using internal PLL for my setup (as suggested in this document https://www.intel.com/content/dam/altera-www/global/en_US/pdfs/literature/ug/ug_altlvds.pdf (see page 51)).
Is there any example PLL configuration for ALTLVDS_TX with center-aligned clock/data?
- AnandRaj_S_Intel
To achieve center-aligned adjust the phase shift of external pll.
Can you recheck the phase shift setting of external pll.
Do refer below links for more information.
Anand Raj Shankar
