SWrig4
8 years agoCenter aligned output clock for ALTLVDS_TX in external PLL mode (Arria V)
I am using the ALTLVDS_TX core for transmitting differential data that was previously received by the ALTLVDS_RX core. The target device is an Arria V FPGA. The input/output data rate is 800 Mbps (40...
SWrig4
8 years agoHi
when generating a ALTLVDS_TX using the MegaWizard, it is not possible to specify a phase shift is the "Use external PLL" option is selected.
For the PLL I am using the phase shifts reported in the resource report when using internal PLL for my setup (as suggested in this document https://www.intel.com/content/dam/altera-www/global/en_US/pdfs/literature/ug/ug_altlvds.pdf (see page 51)).
Is there any example PLL configuration for ALTLVDS_TX with center-aligned clock/data?
