16 years agocase analysis and false path issues
Hi, Is there any feature called case analysis in Quartus2 9.0 edition which allows to select specific path to be considered among three paths going through the 2:1 mux? My design has a cell in ...
16 years agoThank you for the response.
I agree with you that the false path should work and the cell is a DDIOOUTCELL. The tool (TimeQuest) does recognize the the pins and command "set_false_path -through [get_pins {path to muxsel}] " in the sdc constraint file but the element muxsel still shows up in timing report of Data Required Path. What am I missing here? Also, I added the constraint in the sdc file that the launch clock and latch clock which are of two different domains are a specific max. delay apart. The negative slack still shows up. Please correct me if I am wrong anywhere.
