19 years agoCan't find JTAG Server
Why do I get the error message “ Can't find JTAG server” when trying to program by device.
19 years agoI've seen this same problem many times, and it's always been related to one of two things...
1. Firewall installed on local machine that is not allowing the jtagserver to run. Check to see if you have a firewall running (Norton, McAfee, Windows Firewall, etc). Disable the firewall and this might fix it. 2. FlexLM version incompatibility. Sounds like you used to have things working just fine and now you don't, which means# 2 is not likely the problem. Check your firewall...
