Serge93
1 year agoCannot download SOF on Agilex 7 FPGA I-Series Dev kit
Hello Suport, When I try to download my SOF on Agilex 7 FPGA I-Series Dev kit I got the following messages : Info(18942): Configuring device index 1 Error(18950): Device has stopped receiving co...
WZ2
1 year agoHi there,
Based on the error message, it appears that the failure occurred because the FPGA was unable to communicate with the voltage regulator (VR) during the configuration process.
I suspect that the issue may be due to a mismatch between the settings in the project under:
Quartus → Assignments → Device and Pin Options → Power Management &VID
and the actual voltage regulator on the board.
You can refer to the datasheet of your board for the correct settings, or let me know which board you are using so I can help verify the appropriate configuration.
wz
