16 years agocan not verify DDR SDRAM write activity using SignalTap
Dear all, My test SDRAM program works good in Nios II, but I can not verify write activity using SignalTap, anyone can help? I am using Cyclone III starter kit, the given example "Hello ...
16 years agoWill the fetching code affects "local_write_req" and "local_read_req"?
There is almost no any codes related to DDR SDRAM before IOWR: as shown below: # include<stdio.h># include"sys/alt_dma.h"# include "sys/alt_cache.h"# include "system.h"# include "altera_avalon_dma_regs.h"# define length 512 int to_hex(char* pkt) { unsigned int value[8]; unsigned int value1=0; unsigned int q; for (q=0;q<=7;q++) { value[q]=(pkt[q]>0x39)?(pkt[q]-0x37):(pkt[q]-0x30); if (q==0) { value1=(value1+value[q]); } else { value1=((value1<<4)+value[q]); } } return value1; } void Single_Write(void) { unsigned char write_offset[8]; unsigned char data[8]; unsigned int DDR_write_OFFSET_ADDRESS; unsigned int write_data; printf(" \n Single Write operation \n"); printf( "\n Enter the data you want to write to the Memory:(i.e.44444444) \n"); gets(data); write_data=to_hex(&data[0]); printf( "\n Enter the offset address where you want to write in the Memory: (i.e. 00000010)\n"); gets(write_offset); DDR_write_OFFSET_ADDRESS = to_hex(&write_offset[0]); if ((DDR_write_OFFSET_ADDRESS<0)||(DDR_write_OFFSET_ADDRESS>=(ALTMEMDDR_SPAN/4))) { printf(" \n Invalid Offset \n"); printf( "\n You have entered wrong offset address : \n"); return; } IOWR(ALTMEMDDR_BASE,DDR_write_OFFSET_ADDRESS,write_data); if (IORD(ALTMEMDDR_BASE,DDR_write_OFFSET_ADDRESS)==write_data) { printf("\n Data: %08x is correctly written to memory offset: %08x\n", write_data,DDR_write_OFFSET_ADDRESS); printf("\n Write operation is done \n"); } else { printf("\n Write operation is Failed \n"); } } int main() { Single_Write(); return 0 ; } --- Quote Start --- Well, I imagine there's a lot more to your code than just the IOWR command. The processor starts fetching code at the Reset Address. Generate an objdump file and take a look at everything all the code that exists prior to your IOWR command. Additionally, if you're using an "f" core, you likely have data/instruction cache and branch prediction, which means that the processor could be fetching instructions just to fill a cache line. Cheers, -slacker --- Quote End ---
