14 years agoCan CPU win arbitration during DMA operation to the same data bus?
Hi all I am using the SOPC builder for my NIOS II system design. I am having the 1Mx16 SSRAM and the 4Gb Nand Flash both sitting on the same data bus. The SSRAM is for NIOS II cpu instruct...
14 years agoEdit: I misread you, as if you were DMAing from the flash to the SSRAM.
The Qsys fabric Master1 access Slave1 while Master2 accesses Slave2 without contention. What I wrote below only applies when two or more masters try to access the same slave. ------------------ The CPU will given access. The arbitration scheme uses a fairness scheme. By default, it gives each master one access, round robin. If needed, you can change the weights in Qsys. Check Qsys interconnect handbook, 7-10.
