14 years ago
cache memory for reading and writing
Hi all
I am using a memory of 16 8-bit words that is preloaded with specific operands. My memory module has 5 ports which are "dcenbl" to enable the cache for read or write operation, "rdwr" to allow reading (rdwr=1) or writing (rdwr=0), "dcaddr[3:0]" which selects an address in the cache to either read or write data, "dcdatain[7:0]" provides data for a write operation, and "dcdataout[7:0]" provides cache contents for read operation.
When I compiled my code, it is giving me an error showing that
'Cannot synthesize initialized RAM logic "dcache"' for the line reg [7:0] dcache [0:15] in the code.
Can anyone please tell me how to solve this error.
I am running my code in quartus 11.0 web edition using cyclone ii device.
------------------------------------My code-----------------------------------
module mem_dcache (dcenbl, dcaddr, dcdatain, dcdataout, rdwr);
input [3:0] dcaddr;
input [7:0] dcdatain;
input dcenbl, rdwr;
output [7:0] dcdataout;
wire [3:0] dcaddr;
wire [7:0] dcdatain;
wire dcenbl, rdwr;
reg [7:0] dcdataout;
//define memory size:# of bits per reg;# of regs
// 8bits per reg; 16 regs
reg [7:0] dcache [0:15];
//define memory contents
initial
begin
dcache [00] = 8'h00;
dcache [01] = 8'h22;
dcache [02] = 8'h44;
dcache [03] = 8'h66;
dcache [04] = 8'h88;
dcache [05] = 8'haa;
dcache [06] = 8'hcc;
dcache [07] = 8'hff;
dcache [08] = 8'h00;
dcache [09] = 8'h00;
dcache [10] = 8'h00;
dcache [11] = 8'h00;
dcache [12] = 8'h00;
dcache [13] = 8'h00;
dcache [14] = 8'h00;
dcache [15] = 8'h00;
end
always @ (dcenbl or dcaddr or dcdatain or rdwr)
begin
if (rdwr==1) // if true, read op (ld regfile)
dcdataout = dcache [dcaddr];
else // if false, write op (st regfile)
dcache [dcaddr] = dcdatain;
end
endmodule
1 Reply
    An initial statement is not synthesizable... it should be used in simulation only.
    Either you can instatiate Altera's RAM block or use a reset statement in your always block in which you can initialize the values.
