12 years agoBuild a shared library for DS5
I am trying to run the Armadillo Linear Algebra package on my Cyclone V.
I get it to work with general Linux GCCInvoking: GCC C++ Compiler
g++ -I/usr/include -O0 -g3 -Wall -c -fmessage-length=0 -MMD -MP -MF"src/Armadillo_Test.d" -MT"src/Armadillo_Test.d" -o "src/Armadillo_Test.o" "../src/Armadillo_Test.cpp"
Finished building: ../src/Armadillo_Test.cpp
Building target: Armadillo_Test
Invoking: GCC C++ Linker
g++ -L/usr/lib64 -o "Armadillo_Test" ./src/Armadillo_Test.o -lm -larmadillo -llapack -lblas -larpack
Finished building target: Armadillo_Test Then I try to build for DS5 and the cyclone board Invoking: GCC C++ Compiler
arm-linux-gnueabihf-g++ -I/usr/include -O0 -g3 -Wall -c -fmessage-length=0 -MMD -MP -MF"src/Armadillo_Test.d" -MT"src/Armadillo_Test.d" -o "src/Armadillo_Test.o" "../src/Armadillo_Test.cpp"
arm-linux-gnueabihf-g++ -L/usr/lib64 -o "Armadillo_Test" ./src/Armadillo_Test.o -lm -larmadillo -llapack -lblas -larpack
/usr/lib64/libarmadillo.so: file not recognized: File format not recognized
collect2: error: ld returned 1 exit status Any ideas what I could try?2 Replies
Does anyone know if the cross compiler, which comes with the Yocto, should build up the correct library? I followed this but step two fails.
http://stackoverflow.com/questions/21263427/cross-compiling-armadillo-linear-algebra-library Will I need to get another? My error is: gcc: error trying to exec 'cc1': execvp: No such File or directory - Altera_Forum
That error indicates that GCC can't find one of the files it needs to do compiling. It isn't related to the library you are trying to build. You will find that you can't compile anything.
I've seen that error before when environment variables GCC needs weren't set correctly. Unfortunately, I don't know how to fix this for Yocto. Is there a script you need to run to set it up?
