12 years agoBuild a shared library for DS5
I am trying to run the Armadillo Linear Algebra package on my Cyclone V. I get it to work with general Linux GCC Invoking: GCC C++ Compiler
g++ -I/usr/include -O0 -g3 -Wall -c -fmessage-...
12 years agoThat error indicates that GCC can't find one of the files it needs to do compiling. It isn't related to the library you are trying to build. You will find that you can't compile anything.
I've seen that error before when environment variables GCC needs weren't set correctly. Unfortunately, I don't know how to fix this for Yocto. Is there a script you need to run to set it up?
