16 years agobuffer for clock signal?
Do Quartus has an buffer for split the clock signal (200MHz)? ----------------------------- clock (200MHz) | | | | | | |...
16 years ago --- Quote Start --- Hi, I think the Info is a little bit misleading. It only means that Quartus found 3 nodes which drives the clock inputs of e.g. registers. You don't need to do any buffering here, but this kind of clock generation could cause a lot of timing violations. Kind regards GPK --- Quote End --- Hi, You should find a lot of info's under: http://www.alteraforum.com/forum/showthread.php?t=2250. Kind regards GPK
