16 years agobuffer for clock signal?
Do Quartus has an buffer for split the clock signal (200MHz)? ----------------------------- clock (200MHz) | | | | | | |...
16 years ago --- Quote Start --- Do Quartus has an buffer for split the clock signal (200MHz)? ----------------------------- clock (200MHz) | | | | | | | | | node1 node2 node3 --- Quote End --- Hi, in case your are using a global input, the clock is distributed to all parts the FPGA. Kind regards GPK
