Broken JTAG-chain Cyclon V SoC
Hi Mathias,
Can you change the new JTAG cable?
I think we have this issue before that cause by cable it self.
Thank you,
Aliff
- thom623 years ago
Hi Aliff
we can close this support request! +1.1V for the HPS system was not working as expected. For this reason the J-TAG chain was not working properly in the HPS part. From the beginning I was pretty much sure that this might be the reason but I couldn't find the source..
Thank you very much for your time and help..
Best regards
Thom
- thom623 years ago
Aliff
Today we receive a new USB Blaster, the latest version from Intel, I'll make tests with it. Yesterday I made tests with the old one from terrasic and got the following result:
Then I made tests with a Segger J-Link J-TAG interface and its corresponding J-Link Commander app. This test has been performed with a 4MHz TCK clock and I got the same result on TDO: 0xFFFFFFFFFFFFFD55 while scanning the instruction register.
SUMMARY: two custom boards in our lab show the same behavior, two complete different tools also show the same results, TCK frequency has no influence to the measured results.
I think the HPS J-Link is not working in our setup.
best regards
Thom
