13 years ago
Bit Stream wont load
Hi
I have a board that has two EP3C16's and a EPCS16 to hold the bit stream. I am trying to program using the AS mode with the USB Byte blaster. I have set the first device as Master active (MSEL 010) and the second device as passive serial (Msel 000). I have been able to program the EPCS by generating .pof file from the two FPGA's .sof files and it looks be be OK as it verifies in Quartus with no error. The problem is that the FPGA's are not getting the data. It is constantly asking for data as the clock is active. I can see that data is being sent from the EPCS. I have all of the signals on a logic analyzer and I can see the the conf_done signal never goes high
Has anyone got any ideas as to why the FPGA's wont program?
    can you post scope shots of nCONFIG, nSTATUS, and CONF_DONE?
    --- Quote Start ---
    --- Quote End ---
    Thanks for the reply.
    I figured out what my problem was. When I converted the two .sof files. I added them as Page_0 and Page_1 when they both should have been under Page_0.
