16 years agoBeMicro UART Interface no data on RxD
Hi @ all I tried the following vhdl process code in order to receive data from pc com interface: com: process (clk) variable temp : std_logic_vector(47 downto 0) := "0000000000000000000...
16 years agoIt should work, if the serial port is already configured correctly (baud rate, parity, number of bits...)
You can aslo use a terminal (such as termite (http://www.compuphase.com/software_termite.htm), just avoid Hyperterminal), it should make it easier.
