16 years agoBeMicro UART Interface no data on RxD
Hi @ all I tried the following vhdl process code in order to receive data from pc com interface: com: process (clk) variable temp : std_logic_vector(47 downto 0) := "0000000000000000000...
16 years agoI did add the if rising_edge command into the code and know it receives something. I saved a ascii.txt file with an a and used "copy ascii.txt com5:" in order to send the "a" to the fpga.
Do you know if the plain "a" arrives at the stick if i use the copy command as a test? Edit: I only have an Rx signal but no other control signals.
