16 years agoBeMicro UART Interface no data on RxD
Hi @ all I tried the following vhdl process code in order to receive data from pc com interface: com: process (clk) variable temp : std_logic_vector(47 downto 0) := "0000000000000000000...
16 years ago --- Quote Start --- Hi I thought The process itself is clk sensitive, every Time The clk Signal changes The Process gets executed. In your Code example it is just rising Edge sensitive or is there something Else that i Miss at that Point? --- Quote End --- The synthesizer ignores the process sensitivity list. You need to explicitly put an edge-sensitive 'if' to make it a clocked process.
