BeMicro Max 10 Temperatursensor ADC
Can you show your parameter settings for the core? The TSD is on the first ADC in dual ADC devices.
You might also want to check this training that goes into the options for configuring the ADC:
https://www.intel.com/content/www/us/en/programmable/support/training/course/omaxadc102.html
- ivankules5 years ago
so i have done my research and have now tried to implement the ADC without Nios. To do this I followed the youtube video. https://www.youtube.com/watch?v=0oO1RFa-4Xk&list=PLJCQGKgvE0JDbpdW0Apr3fN9lX-VkR3Qz
I have the same chip as in the video the "10M08DAF484C8GES" and I tried to create the ADC design in Qsys according to the video.
Thereby I noticed, he used for the CLK the PIN_M9, where I do not understand the sense, should it not be PIN_N14, which is the input for the systemclock? If you use PIN_N14 instead of PIN_M9 then you get the following error message "Error (170084): Can't route signal "ADC:inst|ADC_pll:pll|ADC_pll_altpll_5q22:sd1|wire_pll7_clk[0]" to atom "ADC: inst|ADC_adc:adc|altera_modular_adc_control:control_internal|fiftyfivenm_adcblock_top_wrapper:adc_inst|fiftyfivenm_adcblock_primitive_wrapper:adcblock_instance|primitive_instance"
If PIN_M9 is used, which should be the input of PLL_1, Quartus compiles the programm. But the ADC Toolkit in Qsys does not start and I get an error message "ADC Toolkit: No associated hardware detected".
This error has already been posted in the forum, again related to the ADC, but with no satisfying answer. https://community.intel.com/t5/Intel-Quartus-Prime-Software/ADC-Toolkit-No-associated-hardware-detected/td-p/1251003
The error must be somewhere when creating the Qsys file or when connecting the pins. I will keep trying, if anyone has any idea or so please write :D. Thank you! - ivankules5 years ago
Thank you for dealing with my problem!
I have only now realized that my FPGA from Arrow has the following identifier "10M08DAF484C8G" and the example I am using is for the "10M08DAF484I7N". The FPGA "10M08DAF484I7N" has two ADCs but mine "10M08DAF484C8G" has only one. This should not be the error, but here are the settings for the core on the two screenshots. I hope the example is valid anyway, otherwise maybe that would be the error already?
I created a repository for the code maybe it helps. If there are any problems in this regard, let me know.https://github.com/GurkenIvanse/bemicromax10ADC
I will take the class.
