9 years agobasic example Avalon MM bus
Hi guys!!!
I'd like to learn to use a avalon mm bus in my Cycone II using qsys, but I dont have a good tutorial where I can learn it . Could you give a good example or reference where can I learn to use it? PD: my FPGA doesn't has a NIOS3 Replies
No, Nios is not required to control things. You could create a state machine as a custom master component. There are lots of free online trainings to get started with Qsys:
https://www.altera.com/support/training/catalog.html?coursetype=online&language=english&keywords=qsys - Altera_Forum
Maybe this document will help?
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/manual/mnl_avalon_spec.pdf - Altera_Forum
I want to implement Qsys without NIOS.
I've attached image where I made a system. I've conected a GIPO (avalon MM slave) with Avalon MM master translator. My idea is using a Avalon MM master translator to send datas to GPIO (avalon MM slave) (I think that system is basic to start :confused:) I've got some questions: My system works?.... If works... How should I setup Avalon MM master translator and GPIO? I've notice through forum and internet that Qsys must be implemet to one NIOS application (Am I right?), because I've couldn't to find a project or tutorial that showing me the opposite.
