16 years agoBad Pins
I am a rookie. I am working on my fourth MAX II design. I am using Quartus II Version 9 SP2. The problem I am having is that several pins on EPM1270 do not work. For example. I have four test...
16 years agoAccording to your posts, it's not clear, if you checked the connection of the said pin in the physical map. Most compiler (or user code related) errors would reveal there.
You can also post your test design as a Quartus archive (*.qar file). If you assume, that's a Quartus bug, contact Altera support.
