16 years agoBad Pins
I am a rookie. I am working on my fourth MAX II design. I am using Quartus II Version 9 SP2. The problem I am having is that several pins on EPM1270 do not work. For example. I have four test...
16 years agoAt this point I am humbled but mostly lost. I have cut out most of the logic and am now down to "glue" that amounts to about 45 LEs. I have four test pins that I reserved for debugging. Device is EPM1270.
If I build a new design that has no logic and just ties the clock input pin directly to all four test pins, it works. (The clock appears on all four test pins.) If I open the 45 LE project above and tie the four pins to the clock, I don't get the clock signal on any of the four outputs. Here are the things that I have tried: - I have tried this on two different computers. - I have replaced the FPGA - I have redrawn the logic - I have deleted the DB folder - I have re-installed Quartus II on my computer. - Device does not get warm. - I have checked all pin numbers - VCC = 3.331 I can't come up with a strategy to solve this. I do get some warnings, nothing that looks significant. I welcome any suggestions. Regards- John
