16 years agoBad Pins
I am a rookie. I am working on my fourth MAX II design. I am using Quartus II Version 9 SP2. The problem I am having is that several pins on EPM1270 do not work. For example. I have four test...
16 years ago --- Quote Start --- Yes, it is certainly possible that there is something wrong with the board. But I have already verified about half of the functionality of this FPGA design. These test pins are only routed directly to Test-points on the board. (They are not connected to multiple places.) Also I have had correct signals on these test pins earlier. Then several pins stopped working. Since I didn't know I could delete the db folder, I created a new design and re-drew the TOP block. I thought that had fixed the problem. I am currently looking at the Technology Map Viewer, and all pins are shown correctly. Thanks for your continued assistance. John --- Quote End --- Hi John, are all your test pins located in one I/O Bank ? Kind regards GPK
