12 years agoAXI read channel - signal rlast "missing"
Hi, I try to get familiar with the AXI protocol. Therefore, I extended an example Design that comes along my EBV SoCrates Board (Lab1_solution). I use Quartus II Subscription Edition V13.1 unde...
12 years agoIf you want to prevent nets from being optimized away you can try this (I copied this from the VHDL templates in Quartus II):
-- Prevents Quartus II from minimizing or removing a particular -- signal net during combinational logic optimization. Apply -- the attribute to a net or variable declaration. attribute keep : boolean; attribute keep of <object> : <object_class> is true; Unfortunately I don't remember VHDL well enough to know how that code is supposed to behave. The lack of a defined reset condition is throwing me off.
