Avalon Streaming simple example
does anybody have a simple example of avalon streaming implementation? I have a system with huge amont of serial data and I want to use avalon streaming interface. simple example will give me an idea of starting point. thanks:)14 Replies
Great, thanks for your help!!!
That's correct, Avalon-MM even has a concept of symbols. 99.9999999% of the time a symbol will be 8 bits (byte) but the reason why even the memory mapped standard supports non-eight bit bytes is for things like transporting parity or ECC information along with the data.
In general if you are moving data between Avalon-ST and Avalon-MM (i.e. a DMA) then usually you use the same symbol size. If you are moving data between ST and MM pay close attention to symbol ordering because most ST IP has the least significant symbol in the MSBs (some people call this big endian.... but 'network order' is the more appropriate name for it) while MM IP is little endian. Some IP blocks are written without the developer knowing about this which can lead to symbols getting flipped around between the two domains. - Altera_Forum
Thanks BadOmen for the great response!
That makes sense. If I am writing to an on-chip memory where each memory cell is a byte, Qsys tells me that the memory's Avalon-MM slave input has symbol width of 8, because each cell is 8 bits. Therefore my signal coming into that memory must also have a symbol width of 8. - Altera_Forum
It's as many symbols as you want. Symbols are similar to bytes in Avalon-MM where it's a unit of data. So you could have for example a 32-bit data port that has four 8-bit symbols, two 16-bit symbols, or a single 32-bit symbol for example (could even have 1-bit symbols although that's usually not useful). Every transfer of data (valid = 1 and ready = 1) the full width of the data is transferred which will be one or more symbols. The restriction is that the data width must be a multiple of the symbol size, or in other words DATA_WIDTH mod SYMBOL_SIZE must equal 0.
If you are designing a streaming block that needs to hook up to some other streaming block, I recommend taking a look at the symbol size of other block. If you took two 32-bit streaming ports, one of which uses 8-bit symbols and another that uses 16-bit symbols Qsys won't be able to connect them. So if you check ahead of time on the symbol size you can save yourself work later one making gaskets that adapt one symbol size to another. - Altera_Forum
--- Quote Start --- Technically you can have an Avalon-ST port with just the data port but in general streams usually don't transfer data every clock cycle or have to backpressure so that's why you typically include ready and valid. --- Quote End --- Thanks for your response! I just had one more question: how much data exactly is transferred each clock cycle? One symbol? - Altera_Forum
It depends on what you need but usually that triplet of signals is all that's necessary. There are other signals in the Avalon-ST spec and depending on your needs you might need them:
error: If you have to transport error information in the data stream channel: If you have to transport a channel number in the data stream (i.e. interleaved channels in the same physical stream of data) sop/eop: If you have to denote the start and end of a packet in the stream (for example if you were transporting Ethernet packets this would be handy) empty: If you need to denote unused symbols in the data stream. (for example if you were transporting 32-bit data of Ethernet packets you can use this to mark how many symbols are empty at the end of a packet if the packet isn't a multiple of four 8-bit symbols). Technically you can have an Avalon-ST port with just the data port but in general streams usually don't transfer data every clock cycle or have to backpressure so that's why you typically include ready and valid. The Avalon-ST protocol is very flexible just like Avalon-MM so there are very few mandatory signals to include. - Altera_Forum
--- Quote Start --- Streaming is a really simple standard to use especially if you have no 'ready latency' Most of the time when I use streaming I use only three signals: data (payload data) ready (tells the data source that the sink is ready for data) valid (tells the data sink that the source is sending valid data) --- Quote End --- That's great to hear! So I it is fine if I ignore the other signals in general? Thanks - Altera_Forum
Hi guys;
I want to use SGDMA to buffer video streaming from a CVI, do you think that it is possible? I have an input of 1080P60. Please inform me if you have an idea about that. thanks. Rabie - Altera_Forum
avalon streaming simple example
what a brilliant performance!!! this is incredible.
