16 years agoAvalon Streaming simple example
Hi, does anybody have a simple example of avalon streaming implementation? I have a system with huge amont of serial data and I want to use avalon streaming interface. simple example will give me...
9 years agoIt's as many symbols as you want. Symbols are similar to bytes in Avalon-MM where it's a unit of data. So you could have for example a 32-bit data port that has four 8-bit symbols, two 16-bit symbols, or a single 32-bit symbol for example (could even have 1-bit symbols although that's usually not useful). Every transfer of data (valid = 1 and ready = 1) the full width of the data is transferred which will be one or more symbols. The restriction is that the data width must be a multiple of the symbol size, or in other words DATA_WIDTH mod SYMBOL_SIZE must equal 0.
If you are designing a streaming block that needs to hook up to some other streaming block, I recommend taking a look at the symbol size of other block. If you took two 32-bit streaming ports, one of which uses 8-bit symbols and another that uses 16-bit symbols Qsys won't be able to connect them. So if you check ahead of time on the symbol size you can save yourself work later one making gaskets that adapt one symbol size to another.
