16 years agoAvalon-MM slave burst mode C example
I've created an Avalon-MM slave using burst mode in SOPC but I don't know how to initiate a burst write in "C". Without burst mode it is just a memory mapped device using simple pointers but how do you send a block of data for burst mode? Using DMA? Using memcpy? Or some other function provided in the BSP?
Thanks,2 Replies
writing some data in a cache line and forcing a flush should write using bursts, if you enabled the burst in the Nios II configuration window in SOPC builder.
Using a burst-able DMA will also work. - Altera_Forum
maybe I am wrong, but I think that a burst transfer would be an "hardaware" prblem, not istantiate in software mode.
Anyway, if you would to start a burst and use "C", i would trigger it with an interrupt from my custom (slave) block to the Nios..
