16 years agoAvalon-MM slave burst mode C example
I've created an Avalon-MM slave using burst mode in SOPC but I don't know how to initiate a burst write in "C". Without burst mode it is just a memory mapped device using simple pointers but how do y...
16 years agowriting some data in a cache line and forcing a flush should write using bursts, if you enabled the burst in the Nios II configuration window in SOPC builder.
Using a burst-able DMA will also work.
