11 years agoAutomatically specify LUT input of Cyclone II device without ECO
I attempt to implement an oscillator inside FPGA using verilog loop. Since delays of 4 LUT inputs(a, b ,c ,d) vary, it's necessary to assign signals to specified LUT inputs to ensure the design is controllable. The code is as follows:
module Signal_Oscillator_P( input iSIG, output POSE ); wire VCC=1'b1; wire combout; cycloneii_lcell_comb \SIGNAL ( .datad(iSIG), .dataa(VCC), .datab(POSE), .datac(VCC), .combout(combout)); defparam \SIGNAL .sum_lutc_input = "datac"; defparam \SIGNAL .lut_mask = "3300"; lcell u(combout,POSE); endmodule However, Quartus drifts off my attempts. The fitting result in chip planner indicates a different routing from the expected, 'POSE' is assigned to datad and 'iSIG' is assigned to datac. Since it's terrible to modify my design with ECO every time I finished compliation, I am seeking for an easy method to ensure the final fitting result matches my verilog code.1 Reply
This is not easy, but has been discussed many times on this forum before. Have a look at the following thread, and the one it refers to. I hope it helps.
[url]http://www.alteraforum.com/forum/showthread.php?t=48915 (http://www.alteraforum.com/forum/showthread.php?t=48915)[/URL] Cheers, Alex
