16 years agoAutomatically save the result after simulation
Hi.. I am going to simulate a design where it takes very long time using Quartus II. Is there any way to save the result automatically after finish simulation?
I run everything from tcl script files. I've got limited experience using he GUI, except for browsing signals.
The following couple of lines are in .do file, after loading into modelsim it can be run with the command '_vsim' on the command line. All the source needs to be compiled first, with vcom (for vhdl) etc. variable tb_name "top_level_entity_name proc _vsim {} { vsim -t ps +nowarnTFMPC -wlf $::tb_name.wlf -wlfslim 512 -wlfdeleteonquit "$::tb_name" log -recursive /* } - Altera_Forum
I want to save all.
I totally new in the scripting. can you explain more details like - vsim -wlf -wlfslim etc options - where to do write the command Can you give me some example ? thanks - Altera_Forum
Depends what you want to save.
If you after all signals then look at. vsim -wlf -wlfslim etc options and log -recursive /* command.
