18 years ago
AS configuration with SPANSION SPI flash
I try to program my Cyclone III (EP3C16) though AS configuration. I do not used EPCS but a SPANSION S25FL016A0LMFI001 which have the same Silicon ID than the EPCS16 (14h) and with the same opcode (ABh).
So when I try to program the SPANSION flash with Quartus II programmer (7.2 SP1) I have the following message :
Error: Can't recognize silicon ID for device 1
So what could I do and look at to solve it ?
Thanks for your collaboration
    Glad it's working. You may have noticed the JIC method can be a bit slow. If you plan to do this for manufacturing, you may wish to look at using the nios2-flash-programmer as a faster alternative.
    Jake
    I thought that the JTAG indirect method used the .pof file :confused: . I translate the .pof file in .jic with EPC3 loader and now it seems good :) .
    Thanks a lot for your help.
    If you are doing the JTAG indirect method (using a .jic file). Then you want the programmer in JTAG mode not Active Serial Mode.
    Jake
    I am using the JTAG indirect method with the Quartus II programmer (used in AS mode) with USB blaster connecting to the JTAG port of the FPGA.
    --- Quote Start ---
    AS mode is reserved for Altera configuration devices. You have to switch to PS mode.
    --- Quote End ---
    No you can still use the Spansion flash. Now how are you trying to progam it? Are you using the active serial method, the JTAG indirect method, or the nios2-flash-programmer method?
    Here this thread on the NIOS forum might give you some insight:
    http://forum.niosforum.com/forum/index.php?showtopic=7695
    Jake
