18 years agoAS configuration with SPANSION SPI flash
Hello, I try to program my Cyclone III (EP3C16) though AS configuration. I do not used EPCS but a SPANSION S25FL016A0LMFI001 which have the same Silicon ID than the EPCS16 (14h) and with the s...
18 years agoGlad it's working. You may have noticed the JIC method can be a bit slow. If you plan to do this for manufacturing, you may wish to look at using the nios2-flash-programmer as a faster alternative.
Jake
