18 years agoAS configuration with SPANSION SPI flash
Hello, I try to program my Cyclone III (EP3C16) though AS configuration. I do not used EPCS but a SPANSION S25FL016A0LMFI001 which have the same Silicon ID than the EPCS16 (14h) and with the s...
18 years ago --- Quote Start --- AS mode is reserved for Altera configuration devices. You have to switch to PS mode. --- Quote End --- No you can still use the Spansion flash. Now how are you trying to progam it? Are you using the active serial method, the JTAG indirect method, or the nios2-flash-programmer method? Here this thread on the NIOS forum might give you some insight: http://forum.niosforum.com/forum/index.php?showtopic=7695 Jake
