16 years agoAS configuration error
Hi all, Stratix II (2s130f780) and EPCS64 (SOIC-16) are used in my project, I have 2 boards, one is ok that is the program can be downloaded with JIC file and init_done pin is high after repower. ...
16 years agoMy comments have been under the assumption, that you correctly reported nStatus has been low all the time from power-on. If you see nStatus low later on, it may simply indicate a failed configuration (without automatic restart enabled). To be sure, you didn't miss a preceeding configuration attempt, you may want to pull nConfig low and check for any reaction at nStatus when releasing it again.
