12 years agoarrow sockit hps_gpio example on eclipse
Hi
I was wondering if this is possible to compile the hps_gpio example for arrow sockit under the DS-5 eclipse. the project compiles successfully by the "make" command under the "altera embedded command shell", but when i create new project in the DS-5 eclipse and copy the source file, i get several error messages that tells me socal/socal.h and hwlib.h and so many files does not exist. how can i add those files to the project? or what procedure should i take to compile this project using DS-5 eclipse? Please give me some suggestion to solve the problem1 Reply
PLZ refer to 《ug_soc_eds.pdf》.
Use the templates in your Installation directory :\altera\13.1\embedded\examples\software I think there is no need to do everything all by yourself, but if u really need to start it from begining , i know a post helps, but it was not write in english i can translate for you. good luck!
