12 years agoarrow sockit hps_gpio example on eclipse
Hi I was wondering if this is possible to compile the hps_gpio example for arrow sockit under the DS-5 eclipse. the project compiles successfully by the "make" command under the "altera embed...
12 years agoPLZ refer to 《ug_soc_eds.pdf》.
Use the templates in your Installation directory :\altera\13.1\embedded\examples\software I think there is no need to do everything all by yourself, but if u really need to start it from begining , i know a post helps, but it was not write in english i can translate for you. good luck!
